Zact Posted February 19, 2021 Report Share Posted February 19, 2021 Hi, I'm having trouble with HMI elements being all out place when I open a saved program. The curious thing is when I select Module 1 of the HMI program to bring up thumbnails of all the screens or hover over a screen name to view the screen thumbnail, the screen appears to be as I saved it. When I click on the screen to open it, sometimes the HMI elements are completely rearranged. I've tried it on several computers and both .116 and .125 releases. Also, the problem does persist if I download it to a PLC/HMI. Has any else had this issue? Attached are some examples of the problem. Thanks Zac Quote Link to comment Share on other sites More sharing options...
bobnorway Posted February 21, 2021 Report Share Posted February 21, 2021 I had something similar once, it occured when I used copy and paste while making the screen. I solved it by using the insert function instead. Something screwed up in the object data base I guess. Quote Link to comment Share on other sites More sharing options...
