AV engineering Posted February 22, 2021 Report Share Posted February 22, 2021 Hi there, Where can i find the swapper version of Visilogic 9.8.65? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 22, 2021 MVP 2021 Report Share Posted February 22, 2021 Just drop a note to support@unitronics.com and they'll be happy to send it to you. That definitely needs to be added to the list on the website. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted February 22, 2021 MVP 2021 Report Share Posted February 22, 2021 The full 9.8.65 is still listed under "Previous Versions" - https://www.unitronicsplc.com/Download/SoftwareVersions/Visilogic/VisiLogic_9_8_65.exe I would just follow the re-naming instructions to use the Swapper and download and install this. Joe T. Quote Link to comment Share on other sites More sharing options...
AV engineering Posted February 28, 2021 Author Report Share Posted February 28, 2021 Quote he full 9.8.65 is still listed under "Previous Versions" - https://www.unitronicsplc.com/Download/SoftwareVersions/Visilogic/VisiLogic_9_8_65.exe I would just follow the re-naming instructions to use the Swapper and download and install this. Joe T. thanks a lot Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted February 28, 2021 MVP 2021 Report Share Posted February 28, 2021 AV please also note this link (and entire topic) in case you haven't read it yet: https://forum.unitronics.com/topic/662-how-do-i-use-version-swapper/?do=findComment&comment=17317 cheers, Aus Quote Link to comment Share on other sites More sharing options...
