Jouqqu Posted July 27, 2011 Report Share Posted July 27, 2011 I am making a kind of wake up alarm. I tried to use Time function variable, but then i noticed that integer value shown in Debug mode isn't same as RTC integer value For example At 01:00 RTC value is 100 but Time Function variable is 256. Is there a way to syncronice those values or should i just use timers and reset them at midnight? Or is there a better way, i might also be blind but i didn't find solution from example projects, witch has been great help while doin my first Project with Unitronics Quote Link to comment Share on other sites More sharing options...
Ofir Posted July 27, 2011 Report Share Posted July 27, 2011 Hi, Which PLC are you using? As I understand you are using the indirect clock functions. Please note that you can set on the HMI Time function variable and enter the time from the display. Quote Link to comment Share on other sites More sharing options...
Jouqqu Posted July 28, 2011 Author Report Share Posted July 28, 2011 I'm using JZ10 - 11 - R16. Thats exactly what i had in my mind but i've tried everything else than Indirect Clock function, and now it's working properly. Thanks for help. Quote Link to comment Share on other sites More sharing options...
