Cosine Posted April 20, 2021 Report Share Posted April 20, 2021 (edited) Good day, I have a problem regarding setting the Time & Date of Unistream USP-104-B10 w/ a CPU for panel of USC-P-B10. I'm using the latest version of UniLogic: 1.31.146, the Firmware of PLC is 1.31.122. I'm receiving a Unitronics Message of "Could not apply command" if I try setting the RTC in UniLogic. My communication from PC-PLC is good since downloading is possible. I also tried setting it in UniApps/System/Time & Date It will just load after I press OK and nothing will happen. Can someone enlighten me on how this happen and how to correct this? Thank you! Edit: It is working now. I don't know how or why. I just left it as is yesterday and after opening it today I can change the Time & Date both via UniApps and Set RTC on UniLogic. Can someone explain why this happen? Thanks! Edited April 21, 2021 by Cosine Quote Link to comment Share on other sites More sharing options...
