Interroga Posted May 2, 2021 Report Share Posted May 2, 2021 THE SUBJECT WAS NOT EXPLAINED IN THE UNILogic Knowledge Base, WHERE THE BLOCK BLOCK MESSAGE INFORMATION, IN ITS TERMINAL INDEX. COMPARE MESSAGES AND INDICATE INDEX? I HOPE WE CAN HAVE A REVIEW ON THE HELP TOPIC. Quote Link to comment Share on other sites More sharing options...
Ofir Posted May 4, 2021 Report Share Posted May 4, 2021 Hi, The parse message works as follows: When activating this block the system checks if the buffer structure of data (linked to this block) is match to one of the messages configured in the messages composer. (Messages that is marked as scanned). If it finds one the index tag will contain the index of the message. If it does not find it the index tag will be -1. Quote Link to comment Share on other sites More sharing options...
