preset counter
What you're looking for is a long integer, which has a maximum value of  2,147,483,647.
You have to jump through hoops to get Jazz series PLCs to play with large numbers.  In U90 software, there are many functions that add to the Jazz/M91 functionality that aren't on the standard drop-down list.  They are referred to as "Special Functions".
Go into the Help on the Contents tab and open up Ladder->Functions->Special Functions without Elements->'Long' Integer functions:
Try using this and post questions you have.  If you have a program you're working on, upload it with your post so we can see everything you're doing.
