a3pl Posted August 8, 2011 Report Share Posted August 8, 2011 Hi Some years ago i wrote an aplication on SCADA system to watch some objects. SCADA is communicating with Unitronics PLC's via UniOPC server and GPRS (some in "listen" and some in "call" mode). Recently somePLCs were added to that system and i wrote additional software tomanage that new objects. But now sometimes Im' getting errors: "Communication driver or PLC fault - (103). (Reset the PLC)" Can I find somewhere which PLC is causing that error ? Any suggestions what should I or the engenier who made PLC+modem system check ? Quote Link to comment Share on other sites More sharing options...
Ofir Posted August 10, 2011 Report Share Posted August 10, 2011 Hi, Which UniOPC version are you using? Please make sure you are using the latest version UniOPC 1.3.8 How many PLCs are you using? Does the error occur randmly or you can point on a specific senario to simulate the error? Quote Link to comment Share on other sites More sharing options...
