viscoelastic Posted July 16, 2021 Report Share Posted July 16, 2021 If you are having an issue with Windows 10 and Visilogic & Unilogic seeing mapped drives. Here is a workaround/fix in the attached image. I requires a simple entry into the registry. Note: this will only work for a User that is currently logged in with administrative rights and already has UAC enabled. This does not work for a User with User privileges. If you installed Visilogic or Unilogic as administrator you already you have admin rights. Other Note: If you are not comfortable editing the registry or understand what you are doing with the registry... THEN DON'T DO IT! And as always create a System Restore Point before you edit the registry in case you do something wrong. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted July 16, 2021 MVP 2021 Report Share Posted July 16, 2021 Now pinned to the Almost Worth Pinning topic in the Vision forum, with a little more info. cheers, Aus. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted July 18, 2021 Report Share Posted July 18, 2021 We do not recommend to work with projects, located at mapped drives, or flash drives of any type. We recommend to copy project to local drive, work with it, than save changed/edited copy back to your archive with a new version number. In case of USB interface problem, or network problem, you can finish with lost projects. Quote Link to comment Share on other sites More sharing options...
