Martin1 Posted October 19, 2021 Report Share Posted October 19, 2021 When I create a array[100], I would like to rename the tagnames. Is it possible to import from excel? I do not see a easy solution. Quote Link to comment Share on other sites More sharing options...
Rivka Posted October 20, 2021 Report Share Posted October 20, 2021 Hi @Martin1, I hope I understood what you are trying to achieve, please tell me if I am mistaken. I've never tried that, so first try it on an empty project: 1) Create an array and use the "export tags" feature 2) in the created excel, edit aliases names to give a unique name to each array member 3) Use in the target project the "import tags" feature. Quote Link to comment Share on other sites More sharing options...
