Issue with VisiLogic Version 9.8.91
I just started using version 9.8.81 and notice the following two issues:
1) When opening a project saved with 9.8.80, there is no notice that you are opening a project from an older version. However, when going to download the project to a PLC, it is required to upgrade the PLC firmware. If upgrading the project requires upgrading the PLC firmware, the programmer should definitely get a notice to this effect.
2) When downloading a project to a PLC, ANY change results in this message:
I am used to seeing this if there are dramatic changes or if downloading to a different PLC, but not every single download regardless of how small the change.
