isaakkis1 Posted December 14, 2021 Report Share Posted December 14, 2021 Hello, I want to be able to use an INT32 OR UINT32 Variable to access and Use his 32 boolean bits. I want to do it without the use of the Function "Num to Bits" like is On the picture attached, is there anyway to address it automatically like it is on Siemens. To avoid extra coding, because later I have to use again "Bits to NUM" Function to convert it again to DWORD. Find relative pictures attached for understanding what I want to do, I want to access the 32 bits in INT32 or UINT32 Variable without the use of the functions above, I just want to know if there is anyway to point their address directly like is on Siemens Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted December 14, 2021 MVP 2021 Report Share Posted December 14, 2021 Please try Test Bit in Ladder Function. Quote Link to comment Share on other sites More sharing options...
