Unitronic V700 Tuning Help - Heater Furnace
There are many topics about PID present on forum. Try to search on forum.
Please post your furnance setup: hardware, sensor installation, heat source, ON-OFF slow PWM or fast PWM output used, temperature range.
If you use Autotuning - please try to set lower (-30 C) setpoint and start Autotuning.
Fix on paper P, I, D settings.
Then start Autotuning on normal setpoint.
You can see what changes appear in P, I, D and understand system behavior with different settings.
Thank you @kratmel for your response and suggestions.
Furnace heater and heat source is -  Ceramic Band Heater Ø110x300 mm (H) V230 2300W W1150x2
Thermocouple type K
Intended temperature range is 250-350 C
I need to ask about slow or Fast PWM
I am a novice in this area, I will get back to you with the missing information.
