Stzyc Posted January 10 Report Share Posted January 10 Hello, I have a little big problem with with Unilogic soft. I am reading a sensor modbus Float register but I can't have the good value writting in a real. Is there someone who could help me please. I have tried some conversion but nothing well. Have a nice day. Stef Quote Link to comment Share on other sites More sharing options...
pascal Posted January 10 Report Share Posted January 10 Stef, had the same problem, but I managed to "convert" the float to real : the problem is that when you read a float trough modbus, the bytes are swapped. you read a float and receive 4 bytes -> this is the way I convert the floating value into a real value I read the float as a buffer of 4 bytes , then I swap the bytes first byte you receive is in fact the 3th byte of the real second is the 4th byte - third byte is the 1st byte and last byte you receive is the 2nd byte a good idea is to check it with this link : https://www.h-schmidt.net/FloatConverter/IEEE754.html Quote Link to comment Share on other sites More sharing options...
Stzyc Posted January 10 Author Report Share Posted January 10 Thank you for the feedback, Finally I found a solution that seems to work for me. The register of my sensor is based on a FLOAT type variable (32 bits) coded in AB-CD or CD-AB. I chose CD-AB. - I read this one with a 4 x 8 bit array variable. - Then I transfer the results with: 'Copy array part' by making my bit shifts: - bit 0 to 2 - bit 1 to 3 - bit 2 to 0 - bit 3 to 1 - then I copy the new variable of type ABCD in a temporary 'buffer' then in a variable 'Real'. It works for me. Quote Link to comment Share on other sites More sharing options...
Stzyc Posted January 10 Author Report Share Posted January 10 😀 Quote Link to comment Share on other sites More sharing options...
