jpecin Posted February 7, 2022 Report Share Posted February 7, 2022 i need help setting up the CRC calculation ASCII command "QIC" has the correct CRC in the form HEX "D6 EA" according to the CRC calculator it is the CRC-CCITT version (XModem) here to check : https://www.lammertbies.nl/comm/info/crc-calculation please help how to set in the dialog I've tried different combinations but none of them work Thank you Quote Link to comment Share on other sites More sharing options...
