MateK SB Posted February 16, 2022 Report Share Posted February 16, 2022 Hello to all, We are in project which requires that operator from one place, one touchscreen, controls (start-stop, change freqencies etc.) of 36 converyors. All conveyor control same VFD model Danfoss VLT 5000 (software version 3.6). We are using V1210 vision PLC with two RS485 ports. We know that VFD-s are pretty old, and we also do not have much experience with Modbus (RS485)communication. We would ask for advice, project sample, anything that can help if anyone had some experience with Modbus comunication with this type of VFD. In attachment , sample of project where we used RS 485 to control Yaskawa GA 500 VFD, can it function in same way with VLT 5000? We also cannot find adequate documentation about holding registers for this VLT 5000 VFD. Thank you in advance for every help, Best regards. V1210 to VFD VLT 500 with RS485.vlp Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted February 16, 2022 MVP 2021 Report Share Posted February 16, 2022 Hi, i find on your foto part number (order code) of two VFD. It is different.... In manual on p.17-18 https://files.danfoss.com/download/Drives/doc_MG52B202.pdf i found that both drive do not support F20 MODBUS PLUS option. F00 - no fielbus... F10 - Profibus not supported by Vision PLC. On p.85 you can find serial comm protocol. It is not modbus but you can run your net via Visilogic Protocol FB. You must run two separate networks for 36 drive run - 31 slaves can be connected to a master, unless repeaters are used. If repeaters are used, a maximum of 126 slaves can be connected to a master. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted February 16, 2022 MVP 2021 Report Share Posted February 16, 2022 Modbus Plus option CARD an modbus registers https://files.danfoss.com/download/Drives/175R5340Rev1VLT5000ModbusPlusIM.pdf Quote Link to comment Share on other sites More sharing options...
