Miloss Posted February 28, 2022 Report Share Posted February 28, 2022 Hello, I want to use this first time PTO output like stepper. I use electronic on 5v to controll stepp motor. I send 5V pulses on stepper drive from mcontroler output. That works with mcontroller but I want to make it with plc. On this unitronics high speed output voltage level is 24 or is it 5V? Can you post some shema how do you controll stepp motor with this, like nema 34 for example. And how many steps per second can this output give? Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted February 28, 2022 MVP 2021 Report Share Posted February 28, 2022 Hi, EXF-RC15 module has 4 npn output. 5Hz-200kHz possible output speed. This two topic is useful for solve your problem Quote Link to comment Share on other sites More sharing options...
