MVP 2021 Ausman Posted March 21, 2022 MVP 2021 Report Share Posted March 21, 2022 Following on from another topic, I'm intrigued enough to ask @Saragani or @AlexUT or @Cara Bereck Levy "How are power up values applied?" Are they effectively "done by SB2 during the first scan" , or before anything is done at all in the ladder? When are they actually set? cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 22, 2022 MVP 2021 Report Share Posted March 22, 2022 I'd certainly be interested in knowing the answer to this as well, but I can't imagine anything other than sometime before execution of the first ladder scan after bootup. It seems to me that anytime before the first scan begins is equivalent. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted March 23, 2022 Report Share Posted March 23, 2022 Hey--remember STL? Does anyone born after {fill-in-date} know that there is STL? 🤪 So--hot off the presses from the development team: Open New project Set PU values: Add some Ladder Logic: Right Click on "!Main Routine" and select "STL View" Reading the above is the best answer 1 Quote Link to comment Share on other sites More sharing options...
