Pedro Borges Posted April 17, 2022 Author Report Posted April 17, 2022 thanks , but I want to have one decimal place in totalizer value in SCADA. for example, the value 6 goes to scada it should appear 6.0 in the SCADA
Pedro Borges Posted April 18, 2022 Author Report Posted April 18, 2022 it's possible to do everything in unitronics by sending the right value with one decimal place to the SCADA without having to divide by 10 in SCADA ?
John_R Posted April 18, 2022 Report Posted April 18, 2022 Gee, I hate to sound smug, but this seems like some situations I've dealt with back when I was still working... I'd spend days trying to show someone how to deal with something, but in the end, the problem was; they were not sharp enough to realize that they didn't understand what they did not know, so therefore they couldn't know what they didn't understand and could not realize where the problem really lay.... Pedro, please do your homework first, then come asking questions...😳
MVP 2023 Joe Tauser Posted April 18, 2022 MVP 2023 Report Posted April 18, 2022 This discussion is actually kind of funny. @Pedro Borges - you're trying to get someone to say "Yes and here's how" to an impossible question. You really, really want to do something that can't be done. By definition, an integer such as a DW, ML, or MI CAN NOT CONTAIN AN ACTUAL DECIMAL POINT. The value in the integer can be 10, 100, or 1000 times bigger than the same number you might see on your calculator, but as Fernando pointed out those are Floating Point numbers, which are very different as far as a computer is concerned. You'll sleep easier if you just accept you're going to have to divide by 10 in the SCADA system and write the result to a REAL data type. Joe T.
Fernando Castro Posted April 20, 2022 Report Posted April 20, 2022 On 4/16/2022 at 2:36 PM, Pedro Borges said: thanks, but this variable also goes to the Scada SCADAS aslo doenst like floats 😂 usually an integer Is sent and the decimal place is shifted, just because flat types uses more memory, for example in binary form: 0.1 = 0.000110011001100110011001101 this one needs 32 bits to be stored 1 = 1 this one needs1 bit to be stored Quote Inside the computer, most numbers with a decimal point can only be approximated; another number, just a tiny bit away from the one you want, must stand in for it. For example, in single-precision floating-point, 0.1 becomes 0.100000001490116119384765625. If your program is printing 0.1, it is lying to you; if it is printing 0.100000001, it’s still lying, but at least it’s telling you you really don’t have 0.1. Decimal to Floating-Point Converter - Exploring Binary In your application I feel like you don't need to use floats, but you do you
