AlexV Posted April 13, 2022 Report Share Posted April 13, 2022 Hello all, Using Remote Operator with a v1210 PLC I have the following issue: When I navigate through the screens from the PLC I don't have any problem and the screens fits all. The problem is when I try to entry to pending alarms and the screen scales to a smaller resolution and tactile keeps the bigger resolution (the good one). When I want to close the alarm window I have to click on right top black corner where ESC is. Is there any way to fix that? Is the only PLC that occurs this problem while other works correctly, fitting the alarm window and tactile to the good resolution. Best Regards, Álex Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted April 13, 2022 MVP 2021 Report Share Posted April 13, 2022 Hi. Please check OS and boot version in normal PLC and PLC with issue. If it not the same - load "normal" version firmware to bad PLC. If it is the same version - please download blank project, reset and init PLC and reload project. Quote Link to comment Share on other sites More sharing options...
