AirCare Automation Posted April 20, 2022 Report Share Posted April 20, 2022 Hello, I am trying to create tutorials on ow to operate the PLC but once the Video is recorded and then played back the mouse is no where on the screen. Is there a fix to this? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted April 21, 2022 MVP 2021 Report Share Posted April 21, 2022 What Vision Model, and what program are you using for your recording? In case a solution is not needed at all......have you also tried doing this with Remote Access? cheers, Aus Quote Link to comment Share on other sites More sharing options...
AirCare Automation Posted April 21, 2022 Author Report Share Posted April 21, 2022 1 hour ago, Ausman said: What Vision Model, and what program are you using for your recording? In case a solution is not needed at all......have you also tried doing this with Remote Access? cheers, Aus I am using Version 1.0.78.0 Unitronics Remote Operator. The Program I am using to screen capture is Called Loom. I have not tried using Remote Access but I will look into it. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted April 21, 2022 MVP 2021 Report Share Posted April 21, 2022 "What Vision Model" is referring to the PLC model number. Unitronics makes different model PLCS, one of which is the "Vision" series. This could have a bearing on your problem as well, due to different HMIs across the models. Quote Link to comment Share on other sites More sharing options...
