Martin1 Posted April 27, 2022 Report Share Posted April 27, 2022 Has anyone setup a Unistream PLC to send/receive data from Home Assistant via Mosquitto broker? MQTT explorer is registering the topic but the data is not displaying correctly. Quote Link to comment Share on other sites More sharing options...
NoamM Posted May 1, 2022 Report Share Posted May 1, 2022 Dear Martin1, Open a ticket on Unitronics "Help center" at https://support.unitronics.com/index.php the Support team will assist. Quote Link to comment Share on other sites More sharing options...
meetingpeople Posted September 11, 2022 Report Share Posted September 11, 2022 what might be the issue in this particular case. It might be something wrong with the connection between the MQTT broker and the client. If you want to understand how this protocol works and how a correct connection is established, then I can redirect you to this article: https://cedalo.com/blog/mqtt-connection-beginners-guide/. It starts with the simplest definitions and then explains the connection itself and the CONNECT and CONNECT data packets. There’s also the Cedalo forum that’s dedicated to tackling Mosquitto tech issues specifically. Quote Link to comment Share on other sites More sharing options...
