Fabios Posted May 14, 2022 Report Share Posted May 14, 2022 Hi, the program that I show you is an unitronics example (MQTT). I notice that for the variable that have a "Power up" value, is not possible to see the value in online mode! Is it normal? If yes, what does it mean? BR Fabio Quote Link to comment Share on other sites More sharing options...
Fabios Posted May 18, 2022 Author Report Share Posted May 18, 2022 OK, they are costant value! Thanks a lot! Quote Link to comment Share on other sites More sharing options...
Saragani Posted May 22, 2022 Report Share Posted May 22, 2022 We've made a fix for next release, so instead of an exclamation mark, the actual value will appear (without the ability to edit it) for constant value. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted May 22, 2022 MVP 2021 Report Share Posted May 22, 2022 17 hours ago, Saragani said: (without the ability to edit it) Saragani, somewhere nearby (next to it?) you should say it can't be edited. Having a number without further info will be just as puzzling. Quote Link to comment Share on other sites More sharing options...
