roghenr Posted June 10, 2022 Report Share Posted June 10, 2022 hello, could you help me? I'm working with V130 and I have doubts about the jumper for communication 485, I posted a photo to guide. I am not having success in communicating with yskawa V1000 inverter, nothing happens to be alarm call. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted June 10, 2022 MVP 2021 Report Share Posted June 10, 2022 Quote Link to comment Share on other sites More sharing options...
roghenr Posted June 10, 2022 Author Report Share Posted June 10, 2022 Hello good day. This is my first modbus project and I have no success communicating with yaskawa v1000 inverter Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted June 10, 2022 MVP 2021 Report Share Posted June 10, 2022 We cannot help you if we can't see inside the Function Blocks. Quote Link to comment Share on other sites More sharing options...
roghenr Posted June 10, 2022 Author Report Share Posted June 10, 2022 Quote Link to comment Share on other sites More sharing options...
roghenr Posted June 10, 2022 Author Report Share Posted June 10, 2022 I mounted cable and used wires one and six Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted June 10, 2022 MVP 2021 Report Share Posted June 10, 2022 Were you able to get your jumpers set correctly? What is the value of MI 89? Are you seeing any increment of DW 2 & DW 3? Does MB 343 turn on? What is activating MB 346? I would start troubleshooting by making MB 346 a positive transition contact rather than trying to run the communications continuously. Have you double checked the settings on the inverter? Quote Link to comment Share on other sites More sharing options...
roghenr Posted June 10, 2022 Author Report Share Posted June 10, 2022 so my doubt is in the estraeamento if this in the jumper if it is correct I sent image like this. Quote Link to comment Share on other sites More sharing options...
roghenr Posted June 10, 2022 Author Report Share Posted June 10, 2022 It's just that I'm alternating cables, for download and for testing Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted June 10, 2022 MVP 2021 Report Share Posted June 10, 2022 3 minutes ago, roghenr said: It's just that I'm alternating cables, for download and for testing Put those operands on an HMI screen so you can see them. I think alternating cables can interfere with RS485 operation. Make sure the PLC is rebooted after removing the programming cable and confirm in INFO Mode that the port is set to RS485. Quote Link to comment Share on other sites More sharing options...
roghenr Posted June 10, 2022 Author Report Share Posted June 10, 2022 44 minutes ago, Flex727 said: Você conseguiu configurar seus jumpers corretamente? Qual é o valor de MI 89? Você está vendo algum incremento de DW 2 e DW 3? O MB 343 liga? O que está ativando o MB 346? Eu começaria a solução de problemas tornando o MB 346 um contato de transição positivo em vez de tentar executar as comunicações continuamente. Já verificou as configurações do inversor? I understand dw2 and dw3 must have values but the problem is that I'm not using separate ports for download and the device in question Quote Link to comment Share on other sites More sharing options...
roghenr Posted June 14, 2022 Author Report Share Posted June 14, 2022 On 10/06/2022 at 11:57, Flex727 said: Não podemos ajudá-lo se não pudermos ver dentro dos Blocos de Função. Olá, boa tarde. Tive sucesso na comunicação com o inversor yaskawa, mas não o endereçamento do comando ligar e desligar e desligar e gostaria de fazer os bits do inversor ligado para mostrar no leitor hm da visão 130. Também não compreende porque somente depois que pressiono F2 o sai o alarme no inversor conforme imagem já enviada no post. Pensei que energizasse ou plc ja comunicaria com inversor automático. Quote Link to comment Share on other sites More sharing options...
roghenr Posted June 14, 2022 Author Report Share Posted June 14, 2022 Hello good afternoon. I was successful in communicating with the yaskawa inverter, but I don't understand the on and off command addressing and I would like to read bits from the inverter turned on to show on the vision 130 ihm. I also don't understand why only after I press F2 does the alarm come out in the inverter as shown in the image already sent in the post. I thought that when energizing the plc it would communicate with the inverter automatically. Quote Link to comment Share on other sites More sharing options...
