Tumminello calogero Posted June 21 Report Share Posted June 21 grazie x le risposte come detto ho un v700 con modulo v200_18_e4xb ho cambiato lo stato delle porte da I9 A I17 passandole a NPN , il loro comune come da manuale gli ho collegato il positivo 24vdc poi ho collegato il cavo nel I9 ho creato una finestara variabile numerica dove ho collegato MI 9 dopo aver mandadoto il tutto nel plc , all accensione non vedo numeri che variano . secondo voi va fatto un programma logico , dove sbaglio T.C. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted Saturday at 09:06 PM MVP 2021 Report Share Posted Saturday at 09:06 PM as said I have a v700 with module v200_18_e4xb I changed the status of the ports from I9 to I17 passing them to NPN, their common as per the manual I connected the positive 24vdc then I connected the cable in I9 I created a numeric variable window where I connected MI 9 after sending everything to the plc, when I turn it on, I don't see numbers that vary. according to you, a logic program must be made, where am I wrong T.C. I9 is not automatically mapped to MI 9 as a counter. You need to create a counter in the ladder code for this to work. Upload your program (.vlp file) so we can see what you've done so far. Joe T. Quote Link to comment Share on other sites More sharing options...
