Juandiaza Posted June 21 Report Share Posted June 21 Hi all, First time I am trying to send an email from my panel, but there is something that probably I am setting right. Does anybody know what is the DNS that need to setup on Unilogic software? I am using a Yahoo account and What I did from command prompt on my computer. I typed: nslookup Yahoo.com Addresses: 74.6.143.25; 74.6.143.26; 74.6.231.20; 74.6.231.21; 98.137.11.163; 98.137.98.164. pick up on red color On DNS Servers Unilogic section: I choose two of the Yahoo servers I found, I guess the problem might be in here. I am not sure if this is setting right. But when I hit a bottom on my HMI to send an email, I am able to see how the status changed to 2 (Function in Progress) and after maybe ten seconds changes to -1 (General COM Error. Please Check the physical connection) (See pics attached) Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted June 21 Report Share Posted June 21 Set DNS provided by your ISP. If PLC is connected to the same network of your computer, then verify its DNS server in network connection details of Windows control panel Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted June 22 MVP 2021 Report Share Posted June 22 You can always use 8.8.8.8 and/or 8.8.4.4. These are free DNS Servers provided by Google. Also, that Default Gateway looks a bit suspect. Usually the last number is a 0, 1, or 255. Quote Link to comment Share on other sites More sharing options...
