Abby Posted July 25, 2022 Report Share Posted July 25, 2022 Hello, I’m using the V120-22-RA22 in visilogic, for the program, I need to make one that cycles VFD 1 and VFD 2 on/off. For example: If my level sensor reads above a value of 10, VFD 1 turns on while VFD 2 stays off. Then the level lowers. Then if the level is raised above 10 again VFD 2 turns on while VFD 1 stays off. My i/o is: I0 VFD 1 FAULT I1 VFD 2 FAULT 0O VFD 1 ENABLE O1 VFD 2 ENABLE AO1 SUMP LEVEL RAW (WHICH IS ALREADY CONVERTED TO FT) I am not sure how to write the program for this. If anyone could help that would be greatly appreciated. Thank you, Abby M. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted July 25, 2022 MVP 2021 Report Share Posted July 25, 2022 1 Quote Link to comment Share on other sites More sharing options...
