krolfson Posted August 25, 2022 Report Share Posted August 25, 2022 Is there an example of controlling an Oriental Motor AZD-CD drive (w/stepper) by modbus to Unitronics US7-B10-TA30 PLC? Do I use the ethernet port to connect to the drive? The motor driver has RS485 inputs. I can control this motor via direct I/O but can't get its position...so I figured that I need to go with modBus. Is there another way? Thanks! Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted August 25, 2022 MVP 2021 Report Share Posted August 25, 2022 4 hours ago, krolfson said: Do I use the ethernet port to connect to the drive? The motor driver has RS485 inputs. No, ethernet port can't be used. You must add com module to PLC with RS485 function - UAC-CX-01RS4 Quote Link to comment Share on other sites More sharing options...
