oobretenov Posted September 12, 2022 Report Share Posted September 12, 2022 I have a project with 2pcs of 0808THS, every Block1 is configured as PWM, 1 channel , with target. when I set PWM Frequency = 50000 PWM Duty cycle channel1 =500 PWM mode = 0 PWM Enable =1 my stepper moves but PWM Current Position is 0 all the time if i set PWM Frequency = 50000 PWM Duty cycle channel1 =500 PWM mode = 1 PWM Target = 100000 PWM Target Enable=1 my stepper moves , PWM Target reached is get 1 afeter some time , but again PWM Current Position is 0 all the time so my problem is "PWM Current Position" - what i did wrong and why PWM Current Position is not count pulses? Any ideas? Thank you Ognyan Obretenov Quote Link to comment Share on other sites More sharing options...
Rivka Posted January 9 Report Share Posted January 9 Hello, Sorry for the long time without any answer. What you describe is actually strange (when PWM mode is 0, it is normal that the target reached does not work, but when PWM mode is 1, PWM current position should not stay 0).I would suggest you to send that issue to technical support. Best regards, Rivka Quote Link to comment Share on other sites More sharing options...
