Angie alvarado Posted September 27, 2022 Report Share Posted September 27, 2022 I am wanting to control this servodrive with the v350 plc version, its output is correct, but when connecting it to the servodrive pulses the motor does not turn, if I connect the oscilloscope it turns but it stays turning, how can I solve this? I attach some images in the drive link. https://drive.google.com/drive/folders/1ff34_CrZ-hKc5mq57GYRFSE2Ge9B5K48?usp=sharing I would greatly appreciate your suggestions. ☺️ Silvia Ávila Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted September 27, 2022 MVP 2021 Report Share Posted September 27, 2022 Please post V350 model # In drive manual for 24VDC pulse 2kOhm resistor recommended to use in STEP, DIR,ENABLE wiring. Quote Link to comment Share on other sites More sharing options...
Angie alvarado Posted September 29, 2022 Author Report Share Posted September 29, 2022 place the resistance but the motor does not turn, the drive does not set any alarm, only the motor does not turn. connect a led and in this if the pulses are reflected. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted September 29, 2022 MVP 2021 Report Share Posted September 29, 2022 Please read in driver manual about enable input. Some driver need to enable by Enable input, in other model Enable input - Disable motion command. By the way - is it motor hold position when driver is powered? If driver is Disabled - motor do not hold position. Quote Link to comment Share on other sites More sharing options...
