Button to Be Deactivated After Pressing
To deactivate the variable - the Disable view option bit present in the properties, for the button - the Disable mode option bit present in the properties.
You can set this bit by pressing a button and starting a timer to reset this bit.
You can also use the Hide option bit for the button - touch is not possible if there is no button on the screen.
  • Thanks 1
