davlo Posted November 15, 2022 Report Share Posted November 15, 2022 Hello, I am very new here to this forum so i apologise if I write anything wrong in advance. I have a school project I would like to make, however i am stuck at a problem and I do not know how to go forward. The project consists of a Unitronics V350 controller, which has a simple program running on it. I have made a server, using UniOPC server with a serial connection with the controller (baud rate, COM port etc...). Added a PLC name and PLC type and the server seems to be working fine. In TIA portal, I have created a project, inserted a PC station, added a IE general comm module and a HMI WinCC RT Advanced module. I added a screen to HMI_RT_1 and the two HMI tags (one Int and one Real). Under connections, I added a new connection and a OPC UA communication driver. However, i am unsuccessful at establishing a connection. Is there anything I am missing? What should be written in the "UA server discovery URL:"? Any tips or guides would be really appreciated. Furthermore, how should a tag from Unitroncis Visi Logic be written for the WinCC to read it correctly? Thank you all in advanced! Quote Link to comment Share on other sites More sharing options...
