FrutigerAG Posted November 22, 2022 Report Share Posted November 22, 2022 Hello I am using a V700 on a battery voltage source with 24VDC for a mobile measuring device. With a V700, is there a way to internally query the current supply voltage to be able to detect a possible voltage drop from the battery? Thanks. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted November 22, 2022 MVP 2021 Report Share Posted November 22, 2022 8 hours ago, FrutigerAG said: With a V700, is there a way to internally query the current supply voltage to be able to detect a possible voltage drop from the battery? Inside V700 PLC present onboard DC-DC 24VDC to 5VDC. From V700 manual: Input voltage 12 or 24VDC Permissible range 10.2-28.8VDC There is no internal circuit for measuring the supply voltage. If you have a Snap-In module with an analog input - you can measure the input voltage through a resistive voltage divider. Quote Link to comment Share on other sites More sharing options...
