Moorthy Posted November 23, 2022 Report Share Posted November 23, 2022 I'm facing some communication problem between Unistream plc and my pc via the usb port. It was working fine all the while. I've checked my pc's usb port- working fine. I've tried to connect with the Unistream plc from another pc- no problem. I'm just guessing the problem could be a result of some recent Windows update so I uninstalled some of recent update to see if solves the problem but not getting anywhere. I'm on Windows 10. Does anyone facing similar problem and is there a solution to this? BTW I'm working with USC B10 TA30. Moorthy Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted November 23, 2022 MVP 2021 Report Share Posted November 23, 2022 Have you tried a few different (new) cables? Quote Link to comment Share on other sites More sharing options...
