JT3798 Posted November 26, 2022 Report Share Posted November 26, 2022 Hello, I have a problem with a V350, when establishing communication with it, it shows me the model as V350-35-XXXX and when loading the program to the PLC, the WARNING 987 "Incompatible hardware configuration definitions: between project (PCModelXXX)" appears. & PLC (PLCModelXXX", could you tell me a way to fix that, thanks Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted November 27, 2022 MVP 2021 Report Share Posted November 27, 2022 In Communication and OS you can check OS version. If it is not updated, Visilogic go to OS update mode and load needed SW to PLC. If this process does not start or fails, please send message to support@unitronics.com Quote Link to comment Share on other sites More sharing options...
