mjarvas Posted January 17 Report Share Posted January 17 Hi, I'm getting Local File Error (-3) when I'm using the FTP Send block. I'm doing everything as described in the sample project using the "/" for the path. I tried to send different files from different folder but no matter what I do I get the same error all the time. What does this error mean? And what can cause it? Regards, Marcell Quote Link to comment Share on other sites More sharing options...
mjarvas Posted January 17 Author Report Share Posted January 17 Here is a screenshot of the code... Quote Link to comment Share on other sites More sharing options...
mjarvas Posted January 17 Author Report Share Posted January 17 Actually, I had a look at the File operation block of Rename. And it describes the Data Tables folder on the SD card as "DT". And also other folders like User Log, "UserLog" are different. Now it is working but why is it not in the help??? Quote Link to comment Share on other sites More sharing options...
