Jhav Posted January 27 Report Share Posted January 27 Hi all, I want to create a idle screen for inactivity. I have looked through past forums and see people mention the use of a general touch bit. Where is that located at? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 27 MVP 2021 Report Share Posted January 27 In VisiLogic, use SB 16. UniLogic has the General.Touched Bit. Both do the same thing. Quote Link to comment Share on other sites More sharing options...
Cam Posted January 27 Report Share Posted January 27 SB 16 is touchscreen is active(has been touched) Quote Link to comment Share on other sites More sharing options...
Jhav Posted January 27 Author Report Share Posted January 27 Thank you. Quote Link to comment Share on other sites More sharing options...
