linnemann Posted February 1 Report Share Posted February 1 Hello I'm building a reusable state machine using an UDFB. I want to detect a rising edge when the statemachine should run to transition from the idle state to the next state. I create the input tags but in the UDFB i cannot use the tag when using Positive and Negative transition contact. I can select it if I use the Direct or Inverted Contact. What is the reason for this and how do you propose i do it otherwise? Attached is a very minimal example. StateMachine.ulpr Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted February 1 Report Share Posted February 1 hi linnemann I think that this happens because also the "function in" variables are consider as "local" so are inizialized at every loop of the program...so the -|P|- will be as a normal -| |- . if you want/need just a "one shot" command you have to reset the used variable at the end of what you need to do. consider that a single variable is passed by value...so you have also use a "function out" to reset it...otherwise array and struct are passed as reference...so what you do with the relative "function in" variable will have a direct effect to the global variables. hope that is clear but mostly that is right. Quote Link to comment Share on other sites More sharing options...
linnemann Posted February 1 Author Report Share Posted February 1 Hi This is also what support said, but if I need to use global variables or structs then the udfb is not really reusable. Any example of how to make a reusable udfb with a state machine and a way to oneshot it from function in tags? Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted February 2 Report Share Posted February 2 hi at the moment i can't write something new...maybe later...for the moment take a look at the following discussion that I have had in thi sforum: LINK Quote Link to comment Share on other sites More sharing options...
linnemann Posted February 3 Author Report Share Posted February 3 Thank you for the link. It does not solve the rising edge ,but it has workarounds. I've added the rising edge in a struct to be a feature request as there should be no limitations as it is passed as reference when input is a Struct, Array or buffer. Regards Quote Link to comment Share on other sites More sharing options...
linnemann Posted February 6 Author Report Share Posted February 6 I have attached a sample project that shows how this can be implemented until UT gets this in as a basic feature. Two input structs are used, one for keeping track og the rising/falling bits and one for the statemachine. StateMachine.ulpr Quote Link to comment Share on other sites More sharing options...
