MVP 2021 Flex727 Posted February 8 MVP 2021 Report Share Posted February 8 I've worked with dozens of V1210s over the years and had no problems, but recently I've gotten at least two V1210s that have touchscreens that require much more touch force than normal. One of them is quite excessive and in fact I thought the touch screen was inoperative as first. Is there something that can be adjusted for touch sensitivity on these PLCs? Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted February 8 MVP 2021 Report Share Posted February 8 I noticed that in some PLCs, the fastening bolts are tightened so tightly that the body is deformed and, as a result, there is a problem with the touch screen. However, I think that the main issue of sensitivity is the distance between the sensor itself and the main sticker film (this is not about the removable film that comes with the new screen as protection against damage during transportation). 1 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted February 9 MVP 2021 Report Share Posted February 9 Flex, some younger fingers, instead of flattened out old clunky ones, might solve the issue!! 🙂 1 Quote Link to comment Share on other sites More sharing options...
