Hello i have some questions about the HSC inputs. im setting up flow rate and i see that the high speed intputs have  the abitlity to measure frequency in multiple ms increments. my question is will the values refresh after after the allotted ms are up?
Yes, it will refresh, this number only indicates with which period the average frequency will be determined.
The frequency will be determined by the number of pulses received per time unit selected by you.
The only remark is that if you have chosen encoder x2 or encoder x4 as a source, the frequency will be 2 and 4 times higher, respectively. And it will have to be divided by 2 and 4 to get the correct value.
