Sensor input or manual emulation input
Hi!
I have an external 4-20ma loop water pressure sensor to tell me the level of the water. This external input would be referred to during normal operation.
For the initial "on-site" set-up of parameters and maintenance thereafter, I need to have the source of the water level data NOT come from my external sensor thru the linearization FB , but from my "% of water" button in the HMI ... to set the emulated water level at will.
How would I code a "switch" of the input sources?
Thanks!
