UIS-WCB2 HSI connected to encoder
Can anyone help me how to use UIS-WCB2 for the position detection?
I have connected Encoder A and B outputs on card inputs, it counting But I need two directional counting and can't figure out how to set it.
I am new with Unitronics so please feel free to propose obvious simple solutions if exist.
Thank you in advance
I think that the user did not select correct option in the HW configuration.
Unfortunately,  user did not specify which settings he selected.
By selecting the quadrature (A/B) encoder option, we automatically select (maybe) that this is a reversible counting device, which also takes into account the direction of rotation of the encoder during the processing of two quadrature signals A and B.
Unfortunately, I do not have such IO on my desk to experimentally confirm or refute my guesses.
Although I may be wrong in my guesses - only the project sent by the user can show what is wrong with the encoder configuration or signal processing from it.
@kratmel @Rivka
Thank you so much for the answer. Last few days I was not near machine so I am able to test it now.
My first setup was as @kratmel suggested, I also tried with High speed type: Measure Length (Pulse Counter) and A/B interface of course.
I have 2 encoders and in both cases during movement value of the tag  UIS-WCB2_0.B1: Counter is alternately changing from 0 to 1. When I stop movement last value remains.
During movement value of the tag UIS-WCB2_0.B1: Frequency is 0.
I need this encoder for position reading so I would like to have some number which I can calculate position from.
