Gabriel Franco Posted March 13 Report Share Posted March 13 This is not a question. It´s a situation I realized and want to share it. As you might know, trend curve Ymin/Ymax properties constant values are limited between -9999 up to 9999 (4 digits). Using an MI (instead of constant value) AND if it is greater than 9999 AND viewing the page containing such trend, THEN that MI is automatically changed to 9999. Keep it in mind to, not to use trends with numbers greater than 9999. This behavior is by software design and confirmed by support tech guy. 1 Quote Link to comment Share on other sites More sharing options...
