Dmitrij Posted September 14, 2011 Report Share Posted September 14, 2011 Hi all We moved a project from previously used V570 to V350 and faced a problem: default white fonts on built-in alarm screens (and virtual keybord) are hardly seen looking from most angles (slightly better from below). Not enough contrast, and it is not adjustable. Darker fonts look OK, but it seemes that there are no standard way to change the color on built in screens. Any ideas? Virtual keybord is not used a lot in the application, but alarm screens are really necessary. Dmitrij Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted September 14, 2011 Report Share Posted September 14, 2011 Hi, few questions: which VisiLogic version are you using? (Try the latest V9.3.1 and update your PLC's system files) this is a new V350 or old one? can you send me the srial number and the project? Quote Link to comment Share on other sites More sharing options...
