V700 , Float to Integer , Integer to Float
Hi , it's my first post,  sorry if i didn't post at the good place.
I'm working on Visilogics , V700 PLC , and i want to communicate with a VAR to pick up Real Value , i recieve 2 Words of 16 Bits , the first for MSW and second for LSW. this is my parameter's value.
I need to interpret this value , but the function in Visilogics to convert Integer to Real are for FIXED point , not FLOATTING point , it means it doesn't work in my case , so i came here to ask you guys if there is something i can do , to avoid having to dissect my both words into mantisse and exosant , and use a formula.
And if there is no function to do it , can you explain to me how to make it simple with this example:  110,1 parameters give me  17 116 for MSW and 13 107 LSW.
This is my first automatician job (that will make me validate my graduate) and i'm still learning , this is the first time i encounter that case , where i have to do it manually so i really need your help please.
I answered something like that a couple weegs ago.
https://forum.unitronics.com/topic/9447-conversion-the-value-of-a-ieee-754-floating-point/
If I understood correctly you have 1 32 bit  float stored in 2 16 bit MI, you can use the structure function to "Copy" those 2MI on a 1MF. Being the standar Float type AND assuming byte order is the same it will work, if byte order is different you can use swap bytes before structure
Register a new account
Sign in
Important Information
