roghenr Posted May 7 Report Share Posted May 7 Good afternoon. I'm using Vision V130 and would like to display a numerical variable. I have thermocouple installed type K 1250 ºC, I need to show temperature up to 780.0 with a comma but when thermocouple disconnected or with failure 1380 ºC. I would like to show the disconnected value without the comma... is there a way? Quote Link to comment Share on other sites More sharing options...
AlexUT Posted May 8 Report Share Posted May 8 No, it is not possible. All temperature measurements are in 0.2 C/F. You can convert temperature to text and show whatewer you want. B.R. Quote Link to comment Share on other sites More sharing options...
