Boot Error with Unilogic 1.33 Build 348 - [Code 7]
Hello,
We have a curious problem after updating to Unilogic 1.33.348. After sending to program to the PLC, the PLC is booting but shows the message below :
BOOT ERROR
PLC (CPU) did not boot successfully [Code 7]
We firt thought that it was a hardware problem so we tried on another PLC and we have the same issue.
Also, unilogic shows the following message "Could not apply command" after the program is downloaded into the CPU.
Thanking you in advance for your reply.
On 5/31/2023 at 2:59 PM, Code007 said:
Hello,
BOOT ERROR
Hello,
Did you Upgrade PLC firmware after Unilogic update?
  • 2 months later...
I am having the same issue.  Did anyone find a definitive solution to this?
NOTE:  I cannot update the PLC FW since this error started to appear.  I cannot even update the RTC?  Just get an error "Could not apply command" to anything I try to do.
We exchanged the PLC on this site. With the new PLC everything works fine.
Then we tested the Boot Error PLC on my desk - no problems for 3 weeks. So, we decided to use this PLC for a monitoring task at a customer site. Since approx. one week the PLC is offline (the PLC was doing the task before for more than 2 weeks at this site). I can't tell now if the PLC is completely dead now, or it is just a network issue…
Try it with another PLC and write a ticket to the support. Maybe they got some chips which are not completely ok and more sensitive to environmental conditions (e.g. temperature...).
