micapp Posted June 5 Report Share Posted June 5 My 15.1 " Unistream use 5-10 seconds to switch from one diskplay to next. The CPU is from 2018 but the display is bought in april this year. The main screen has about 250 objects. On a 10" PLC the transition is almost immediate. Operation on screen is immediate, except alarmscreen where selection of alarms takes many seconds. Quote Link to comment Share on other sites More sharing options...
MVP 2022 kratmel Posted June 5 MVP 2022 Report Share Posted June 5 Please send this quastion to support@unitronics.com. You can also send project to support for test. You do not post Display model #.... I think that this is either a problem with the program you wrote or a problem with reading the internal flash card that is built into the panel (if it is Unistream modular). Quote Link to comment Share on other sites More sharing options...
AlexUT Posted June 5 Report Share Posted June 5 Display of 10" with many elements scalled to 15.6" will require more CPU time to re-draw elements. This is why display switch time may be long. You have to check PUsage (System->RunTime) to be sure that CPU is not full loaded. In common, having 100s of elements, many trends, or many animated images at display you cannot suppose it will work very fast. Quote Link to comment Share on other sites More sharing options...
micapp Posted June 11 Author Report Share Posted June 11 Is this ok? Or will this have impact on display switching? Quote Link to comment Share on other sites More sharing options...
