How to use the "Lists" feature?
Can someone help me out to understand how to use the Lists feature found in the solution explorer. I don't see anything in the help files. I can see that there are many types of Lists available, and I can easily create Lists, but I don't see where/how to actually use or reference the List(s), once created.
  • MVP 2022
I didn't know about this one, so I went digging.  There are so many hidden nuggets in UniLogic!
There is some information about Lists in the Help under "For" Loops, specifically as an input argument in the "For Each" function block.  I couldn't find an example on them.
Any input from the Creators on how this works?
You can use lists as an argument for the "for each" loop without having to manage the max iterations of a typical for loop.  Here is a quick example of the for each with a list:
Current Item tag is a local tag similar to this C example:
bool list[10];
int PE_Active = 0;                                         // INT16 in UniLogic
for (int index = 0, index <= MAX_INDEX; index++){
   if(list[index] == true){
         PE_Active += PE_Active + 1;
OK. thanks.
This brings up a new topic now...Combo Box list of text source
I was hoping I could utilize the "Lists" with combo boxes somehow...I would like to have the "Options: List" collection of a combo box be sourced from a dynamic list, or data table column of strings.
Currently, the list for the combo box is fixed and can't be changed thru program code or operator entry.
I wonder if it's possible to somehow link a data table column of strings, or a list of strings to a Combo Box or "List of Text Variable"
Thank you @curtharrington1 for clarifying the feature.
It is indeed a new feature that was introduced, along with the "for" and "while" loops.
It is worth having a look at them!
About the feature request on the dynamic combobox, that could be a nice feature.
I'll open a feature request on it.
Have a good day!
Rivka
  • NoamM changed the title to How to use the "Lists" feature?
  • 1 month later...
