curtharrington1 Posted July 3 Report Share Posted July 3 I noticed I am getting an error after every download in UniLogic v1.33.348 which looks like this: The program downloads to the target and goes online after hitting ok. This seems more like a nuisance than a critical issue at the moment, is there anything I can do to fix this? Quote Link to comment Share on other sites More sharing options...
MVP 2022 kratmel Posted July 3 MVP 2022 Report Share Posted July 3 Please read this topic Quote Link to comment Share on other sites More sharing options...
Saragani Posted July 4 Report Share Posted July 4 After download, the PLC is still busy on loading the new project, or the changes. For an advanced security, the online support in the PLC is only being activated when it is being requested by UniLogic. Since the PLC is busy, it might not reply on time and the request might get timed-out (UniLogic has 3 retries with 500ms between each request), and in that case you get the message that the command could not be applied. Since the Online communication works, then it is only a false-positive. The command is actually applied, but the PLC does not reply UniLogic on time. I can increase the wait for response time-out and also the wait between each retry and the number of retries, and it will reduce the chances of getting this message. You didn't specify the version of the firmware you are using, so I hope that you are using the Official firmware that came with UniLogic 1.33.348 (firmware version is 1.33.260). If you are still using the firmware that came with UniLogic 1.33.210 (which I think is 1.33.149), then surely the command will fails (Even when you start Online from the Ribbon), since this command is only from firmware version 1.33.189 (where the official released firmware version with UniLogic 1.33.348 is 1.33.260) Quote Link to comment Share on other sites More sharing options...
