MELDAW Posted July 24 Report Share Posted July 24 Hello, I am using USC-B5-TA30 and i ordered UAC-CX-01RS2, but i cant connect the com module. to the PLC, did i miss something that i should have ordered or something? Quote Link to comment Share on other sites More sharing options...
DanT Posted July 26 Report Share Posted July 26 Hi; UAC-CX-01RS2 to the PLC USC-B5-TA30 -- Will NOT Work. UAC-CX-01RS2 is for use on the US5/US7/US10 Models. USC-B5-TA30 requires UAC-CB-01RS2 Com Module - it sits beside the USC CPU on the DIN Rail. Contact your distributor. DanT Quote Link to comment Share on other sites More sharing options...
MELDAW Posted July 26 Author Report Share Posted July 26 Hi, Ok thank you so much for the informations. Quote Link to comment Share on other sites More sharing options...
